SpaceBus
If TEGs ever improve they would be right at home on an appliance like a woodstove, especially a cookstove.
An air cooled TEG capable of even 25-50 watts would probably push this into the realm of practicality. That could trickle charge a solar battery bank since most of the time the stove is hot the solar panels are dark. Solar with batteries would already have the inverter and other parts. Something that could sit under the firebox in the bottom drawer of my cookstove would be pretty cool since it's not hot enough down there to require the water cooling and I can't really use that space since a bit of ash falls in when I open the loading door. Sometimes I proof bread quickly on the oven side. I would gladly sacrifice some space on the top of my Morso to generate that much power. We only use a few Kw per day, and more use in the summer than winter.There are commercial products right now that deliver useful amounts of power from a stovetop, but they can cost as much as the stove. (Also, we're talking 100w, not 10kw.)
It sounds better than it actually is,, too.. So let's say you set up a 100w liquid cooled TEG- already more complexity than most people can handle. Now you have peak 100w@12vDC. So you probably want 120vAC... and you quickly find that 100w is somewhere between 0 and 100w depending on stove output. So now you have an inverter and a deep cycle battery and a charge controller.... which is actually a pretty useful setup, but again, way more complexity than most people will be willing to take on.
An air cooled TEG capable of even 25-50 watts would probably push this into the realm of practicality. That could trickle charge a solar battery bank since most of the time the stove is hot the solar panels are dark. Solar with batteries would already have the inverter and other parts. I would gladly sacrifice some space on the top of my Morso to generate that much power.
Wow, I didn't realize they had become so advanced. Too bad the documentation is so minimal. I'm curious about how much power is developed at what temperature.https://www.tegmart.com/thermoelectric-generators/wood-stove-air-cooled-45w-teg
A deep cycle battery runs $100-$200, a small charge controller is $25ish, and then you need an inverter to run off the battery ($25-$500 depending on what you need). So you could do it without a solar setup.
I'm just wondering what the "sweet spot" is for heat. My wood stove cruises around 700-750 on the stove top, but the warming drawer on my cookstove is much cooler. The candle powered TEG mentions it makes most power at room temperature, which is confusing since the candle is clearly hotter. Admittedly I don't know much about TEGs, and I also have no intent on buying one soon. I was just curious about this since it seems like TEGs have great potential in off grid scenarios.Well... that is well documented on the TEG datasheets, which are public and free, but commercial product makers don't tend to get so detailed. Even if you got them to disclose which TEG modules their products use and pulled the datasheets, you'd be less well informed than you might imagine. The reason is that power generation depends on the temperature differential between the hot side and the cold side. So the heat applied is one part, but the cooling on the other side is just as important. (This is why the bigger units are all liquid cooled.)
Anyway, all that means that unless the manufacturer gives you some real world test info that shows how their heat sink and fans cool the cold side of the TEG, you will be able to guess what hot side temps will be in actual usage, but not cold side temps, and you need both to figure power output.
Valid points, definitely. Currently the TEGS are pretty spendy for the power generated. Maybe it's a technological dead end?Agreed, off-grid, you could have 20 or 80 watts of battery charging even when there was no sun or wind... but honestly, dollar per watt, you are better off just getting more batteries and more solar panels. Even small wind turbines are more practical. Also, those who don't cook on their stoves won't want to burn their wood stoves in July to get 80 watts of charge.
And all of the above require a battery bank to be practical. Battery banks require regular replacement (sure hope the grid doesn't go down so I can keep buying batteries so I can be off-grid!).
One of the old posts mentioned the dream I have: a wood furnace, stove or boiler that nly requires a plastic exhaust and intake pipe. Imagine being able to place your wood stove anywhere with the only limit of being able to run 2 pvc pipes to it!
I also echo what others have mentioned about automation of air controls. That seems like a no-brainer to me.
