Gooserider said:
DonCT said:
The HearthStone Heritage has side load.
Mine takes 21" logs, and I try to cut to 19-20. I can fit about 20 or so BioBricks in.
Burn times around 9-10 hours with plenty to relight.
The stuff I've seen on the Hearthstone said that it was BOTH front and side load, and that the while the side load door could be disabled, it wasn't possible to disable the front load door.
Now I'm not a code expert, but my understanding is that even if you don't USE a load door, if it can be opened, you have to have the 16-18" hearth depth in front of it. Our current hearth setup would only have about 6" and I'm not willing to give up that additional foot of floor space. (Nor do I think it would be easy, since presumably it would take major work to make the extension fireproof - I can't just stack bricks on the wooden subfloor...)
Gooserider
Welcome to Massachusetts building codes, Gooserider.
![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
Although I'd be surprised if any other state was much different. The building/fire inspector has two choices in determining minimum clearances, state/town codes or accepting the distances posted on the panel on the stove (or in the owner's manual). Normally they will take the latter and go w/ the mfgr's recommendation. So unfortunately, if the stove has distanceX printed on it, then you're probably stuck with it. There are two bldg inspectors here in Billerica (yes, Im right down the road from you).....one of them I know would probably allow the lesser clearance if you sealed the front loader or persuaded them you'd never use it, the other lives to give grief to every homeowner in town since he is angry about every being born.
If you can get your hands on a used Russo stove (they dont make new ones anymore), they were GREAT sideloaders (grew up with one) and had a glass plate front for viewing, but it didnt open so it had very short clearances for the front (could be removed for cleaning).
