What is correct activation laddomat temperature for EKO-60
cguida
122
Eastern Maine
Title says it all --
If I were ordering a laddomat for an EKO 60, what activation temperature should I specify? Is there a 'correct' temperature, or does it depend on circumstances? If you use a laddomat or termvor(?) what temperature is it set for?
Thanks
Smee
Smee,
The Termovar that came with my Solo 30 was 72C. I seem to remember in another thread that others were getting there Tarm products shipped with this same Termovar.
Smee,
Will you be using the boiler in conjunction with a storage system? The typical 72 degree valve is good for "cold starts". If you are starting up the boiler when return temps are higher 120 to 140, I think a 60 degree valve(less bypass) would be somewhat better.
