ABMax24
That’s a standard pressure. Propane is 11.3-14 WC. Part of the problem is if you run a screw into a line in the wall you won’t hear the leak.
6.16.4 Tubing run inside hollow walls or partitions within 1.75 in (43 mm) of the surface shall be protected against physical damage and puncture at the joists, studs, and plates by the use of No. 16 GSG (1.59 mm) plates or sleeves.
This is why that isn't an issue here. You can't actually get a screw through the shield plates, you need a framing nailer to do that, no one I know hangs pictures on the wall with a framing nailer.
But I'm done with this conversation, it's way off topic anyway, and really serves no use, gas leaks simply aren't a big problem here where I live.
Turn off the propane to this furnace. It is possible the heat exchanger is cracked or rusted out in an area.
