WoodyIsGoody
Insulated my liner with the Everguard pour down mix.
How do you insure the liner is centered when using a pour down mix?
I don't like that you got shocked but I do like that you were working on your stove assembly and found a hazard that could've potentially ended in a fire or much worse than your shocking discovery. Good thing you don't have a pacemaker.Started telling the wife she will have to take her "stove decor" down soon. Did my usual visual checks of stove then went out to check the OAK intake and WHAM! Got lit up soon as I touched metal. Thermo controlled stove blower was still plugged in the wall (swear I unplugged it) and was turned on. Guess I'll find a short somewhere.
Most blower systems have the ground wire attached to the chassis to avoid this kind of hazard. Has me wondering if the outlet is properly grounded.I don't like that you got shocked but I do like that you were working on your stove assembly and found a hazard that could've potentially ended in a fire or much worse than your shocking discovery. Good thing you don't have a pacemaker.
Something's not right.Most blower systems have the ground wire attached to the chassis to avoid this kind of hazard. Has me wondering if the outlet is properly grounded.
@ Dobish- You have two helpers?
Registered it with the air pollution control board. Now I can burn on "registered" days.
This all sounds like some scary movie.
How many cords does the represent?This was from the chimney clean the other day....
Ok, it did look like a healthy amount but that explains it. Dry wood rules!About 2, but this was sub par wood.
