Yep, hence my qualification of efficient burning.Lol, that is possible with any stove, at least the burn 18 hrs with 50 pct wood. It'll be smoldering all the 18 hrs long - but having to evaporate all that water may leave zero BTUs for your home... (Not to speak of what will happen to the chimney)
Isn't this a fantasy thread?Physics prohibits that. Gotta spend the energy to evap the water. Hence not efficient.
Yes. Was thinking my wife needed more draft. Let's not go there.Maybe you were thinking of fantasy after @Caw s post... 😜
I figured it was something like that. The main difference is they were actually trying to clean up a stove’s operation .
I’m trying to amuse myself. If it cut my draft down a bit and 1gph of particulate out of my flue gas I’d consider it a win.
![[Hearth.com] What do you wish for? [Hearth.com] What do you wish for?](https://www.hearth.com/talk/data/attachments/310/310250-27d524a270c3e2cc1d4d911c1fca8494.jpg?hash=nEoJLKA1AM)
Under US epa emissions.. if the stove is functioning to its design there shouldnt be enough fuel in the emissions to light off the cat to get the heat boost needed to operate that.Oh yes, it's something that's going through my head, cat inside flue, and a heat exchanger, like this one in the photo,
or different, above the cat, to take advantage of that heat, but a damper would be needed...
...smolder 18 hrs. when I have only 50% wood. 😆I wish my wife would....![]()
Yeah? You don’t think there’s a time between cold start and when secondaries start rolling that a little can’t be scrubbed?Under US epa emissions.. if the stove is functioning to its design there shouldnt be enough fuel in the emissions to light off the cat to get the heat boost needed to operate that.
Rotflmao!...smolder all day long when I only have 50% wood. 😏
Not really, during the incipient stage and fire growth stage, fire will double in size every 30sec, by the time a stack gets warm enough to make a cat active +650deg the actual fire in the stove box is prob well over 1,000deg f and almost ready for full secondary production which starts at 1500deg f within the body of the fire itself. Then you would have to factor maintaining a stack temp to keep a cat active which presents its own problems since more energy is needed to sustain, so just stick with the internal secondary production produced by air agitation within the firebox itself.Yeah? You don’t think there’s a time between cold start and when secondaries start rolling that a little can’t be scrubbed?
Right. What I'll sometimes do is throw flame heat to the cat to get it burning earlier than it normally would, based on temps in the the top of the box surrounding the cat. As long as I continue the flame heat, the cat will keep burning. Then the top of the stove heats up and I can cut air to a black-box burn.by the time a stack gets warm enough to make a cat active +650deg the actual fire in the stove box is prob well over 1,000deg f and almost ready for full secondary
How are they gonna make money doing that? 😏 That smacks of un-American anti-capttalism, and we'll not stand for that kind of talk, sir! 😆I wish a generation or two could experience world peace.
nd Bholler is correct. A EPA will require a tests at each w.c. that the stove can be run at. Remember combo stoves that could run on pellets, wood, switch grass pellets etc.? They are all gone because the testing is vastly too costly.There were key damper cats made. They didn't work out
So when we bought Fabco, which made superb secondary combustion stoves, we started by introducing the Briarwood. I do not want to tell you how many people called, wrote and emailed me that "this thing is no Blaze King." We must be true to ourselves. Now, I really thought you were going to say a 6 cu ft stove!Blaze King should build a large non -cat lots of people don't get the concept of running a catalytic stove correctly, something with a 10 +hour burn,minimum 3.5 ,4 cu foot firebox.
Dear UL, I want to attach a ignition source to a wood stove that has either an LP or NG fitting to help light the fire. Oh boy that will get them rolling....i wish my wood stove had a propane fire starter like my fire pit has. In my pit you stack up the wood, open the valve on the propane bottle and lite it. When the wood is burning shut the propane off.
It would make all those cold restarts effortless.
