Why are there so many non blower users?
Thats funny, my wife, kids, and I all like to have some drowning noise....Before the wood stove, we always had a forced air furnace. I'm a light sleeper and often awoke when the furnace kicked on. I love the quiet of
my home without any blowers. The only sound I hear in the still of the winter night is if the hot water heater happens to kick on. My home has
good air circulation so a blower isn't necessary.
Kids all have those waterfall/rainforest/summer night sound clocks in their rooms, while wifey and I run a box fan in the BR all night long....even in the winter.....I GOTTA have something to lull me to sleep.....
Yep, and when that happens in a structure on fire (just like a wood stove only no chimney until we make one) it is called a backdraft. It can be deadly......heat, fuel, but no oxygen. If it gets the oxygen some how.....boomYep, and someday it just might "woof" at you as the gasses that built up which couldn't be ignited take off all at once and blow the door open, ash pan open, pipe out of the top of the stove, seam open on a pipe, etc.
Make sure you have 3 screws in EVERY joint, and attached so that it can't come out of the thimble if going into a masonry chimney for that day you experience what BBar is talking about for yourself.
pen
350 to 450. First year burning, still learning, not the most seasoned wood, no ss liner, and my thermometer I think is not the most accurate. Is that enough excuses for not burning hotter?
But we are warm in the house and everyone is happy!
Keep the brush handy an run it down that chimney at least once per month with those conditions!
pen
They just don't understand - or at least appreciate the physics of thermal energy transfer!
As far as 'normal temps' - I use an old pyrometer from a crematory oven to monitor my stove top... if that gives some ballpark idea. Cruise at 600ish for general use, 850+ when I need lots of heat, if you want to talk actual numbers.
Yep. I don't think there is any question about that. You have to figure out and know your stove not someone else's stove. Just my humble opinion.Is it possible different brands of stove are going to show different temps? My stove manual says to run at 250-550 for more efficient burn. yet some on here are reporting 700 degree stove top temps? Mine averages high 400's, low 500s in the hottest part of the burn cycle but will drop to low to mid 400s for the middle part of the burn and eventually stall at 300 or so at the end with coals. My house stays near 70, and i get pretty long burn times so i figured that was normal. But i'm seeing people report 700 degrees, Id think that be over firing if i did that in mine. Im getting good secondaries
Is it possible different brands of stove are going to show different temps? My stove manual says to run at 250-550 for most efficient burn. yet some on here are reporting 700 degree stove top temps? Mine averages high 400's, low 500s in the hottest part of the burn cycle but will drop to low to mid 400s for the middle part of the burn and eventually stall at 300 or so at the end with coals. My house stays near 70, and i get pretty long burn times so i figured that was normal. But i'm seeing people report 700 degrees, Id think that be over firing if i did that in mine. Im getting good secondaries
4. For Maximum Efficiency:It says that in your manual? Where does it tell you to measure from? I'm guessing it says a location that is either not the hottest part of the stove, or you have a soapstone stove? What's the make / model?
pen
When the stove is hot, load it fully to the top of the door opening, and burn at medium low settings.
When the fuel is mostly consumed, leaving a bed of red coals, repeat the process. Maximum heat for
minimum fuel occurs when the stove top temperature is between 250 °F (120 °C) and 550 °F (290 °C).
The most likely causes of dirty glass are: not enough fuel to get the stove thoroughly hot, burning green
or wet wood, closing the draft until there is insufficient air for complete combustion, or a weak chimney
draw. Indeed, the cleanness of the glass is a good indicator of the stove operating efficiently.
Enviro kodiak 1700 freestanding, not a soapstone
stove top with the blowers on low, for the first month. Cools down after that and I'll have to re-load.
