The best way to tell if a WG is gasifing is to put a probe in the back door.
https://www.hearth.com/talk/threads/my-woodgun-doing-its-thing.94245/#post-1241654
Although it would be nice if we could put a view port![]()
I don't know. Would the cable/wire bend and get damaged?I wonder if we could get away without drilling the hole and just run the lead through the rope gasket. Think it would survive?
I tried a bare thermocouple lead...it didn't survive.
If I get the tank I want, have my eye on adding a flue gas condenser next to the Froling.
Flue gas condensor?
Please tell us more
Make, model, efficiency gain, ... .
Homemade. I expect to get the tank scrap, pipe the flue to the top, continue the flue out from the bottom, and drill a small hole in the bottom for the condensate to drip out to a trap. I was thinking along the line of two 50 gallon propane tanks in series, or a salvage takeout from work - extra heavy steel DHW heat exchanger, 6 ft tall, 30" diameter, lifetime steel wall thickness.
I have a 12 ft. sideways throw of inside flue pipe, space to ceilng mount two propane tanks, or floorstanding adjacent to the Froling if I get one bigger tank.
I am not concerned about corrosion. If it rots through in 15 or 20 years it goes to the scrapyard, where it was going before I intercepted it. If it corrodes through, yank it and swap in another scrap, salvage unit. I am thinking just ignore the ash and gum from the condensate, just a filter that lets the H2O out the bottom, and treat the tank as a limited lifetime wear item. When it gets futzed, scrap the tank and put another in.
The idea would be to just waste out the heat from condensation into the basement, which would be bad in the summer but not excessively with a small fire for DHW. I would need some type of filter for the condensate water so the condensate pump runs cleanly.
If the industry advances to the point this becomes manufacturer supplied and supported, you may in the future have the option of trading the cost of the stainless UL HT 103 all fuel flue for the condenser and venting with PVC, like condensing gas boilers. For now, I would continue out through the existing stainless all fuel flue for code. A manufacturers unit would need a way to separate the ash and gum from the H2O and be cleanable. This shows the market is still not fully mature.
If you look at something like the Weil McLain Ultra gas boiler, they use a V shaped downdraft aluminum block heat exchanger and just collect the condensate at the bottom. Something simple.
The Froling is draft induced. Removing the bulk of the H2O from the flue draft should be an improvement.
I was getting icicles too. I think it is a combo snow and ice and the steam from the WG. Was happy to see this thread as it was nice to know it wasn't just me.
Hey glad to be of help. thats why I throw this stuff out there.
I'm not gonna act like I got it all figured out.
And even if past experiences proved to be different and I should be concerned, if its happening now I want to see why.
And I trust that I will get good feedback from this place.
How ya doing up there? We got pounded with 24" how 'bout you?
34 inches here. Things are good. Had an incident with my woodgun as well, but was too embarrassed to post. I had a blockage in the transition from my horizontal run into the main stack. I had cleaned out the other sections, but not this one connection i overlooked. Popped every seam on the 26 gauge steel and filled the basement with smoke a week ago at midnight. Not good when a fireman has to call his own fire dept for a possible chimney fire. Very stressful evening caused by poor maintenance on my part. Ash is getting past my cyclone and collecting in the pipe. I think I need to clean it monthly going forward.
Not to rain on your parade or tell you what to do but I would avoid this particular temptation. Reason being that even if it works (physics says its possible) what do you do with the condensate that will likely be classified as hazardous waste? Toxic sludge basically from a cord wood fired appliance. No one is going to want you dumping that anywhere near them. Not sure what disposal of hazardous waste costs in your area, here it's high. Then there is the accelerated corrosion of the appliance flue/chimney to consider & cost out. Was the appliance ever designed to be operated in a condensing mode? The cooler the exhaust gets the more resistance it will offer to the fan doing the pushing. Is the fan designed to resist this higher level of corrosion? Plenty of factors to consider when moving from conventional or draft induced/assisted to condensing.
Ct,
I have found the best way to avoid this is to check your ash cyclone every other day or so and be sure it is not plugged just above the ash pan. If the ash can not get down into the pan it gets forced further along the the pipe and settles in. I have done away with almost all horizontal piping. And with keeping the bottom of the cyclone unplugged I have greatly reduced any build up of ash in my pipe from cyclone to vertical chimney.
