I have to admit, I dont weld often enough to be able to make consistent good welds with a stick, never have. I also find that my lungs appreciate the vastly reduced amount of smoke from a MIG. Most pro welders usually end up with impaired lung function and eventual lung disease. Once I got a helmet with auto darkening I could get reasonable mig welds in a few minutes after months of not welding. One thing that has changed radically is the size and weight of welders. The old welders were heavy as they were a big transformer, the new ones are inverter based and lightweight. I can run my MIG off a 6 KW generator and make it portable without having a dedicated gas drive unit. Unless someone is production welding with a high duty cycle the old transformer style are not needed. I have not done it but seen the results of hardfacing surfaces with a MIG and its impressive. The trade off is that is probably a good place for an old style transformer welder.
I have a similar cart for my Lincoln. Harbor freight has lighter duty versions that will work.
