Yes you need a pretty good temperature differential to make the water heater exchanger work. Takes about 5 degrees of heat out.
There are several variables that need to be nailed down, but for the most part, electric water heaters are 100% efficient. If you know how many gallons are heated, or how many KWH's are used, it's a quick calculation.That was one my questions about these and was looking at cross links too. I'd love to remove my electric water heater bill, but I wonder how much more it would cost me to heat both the home and the water heater. Any analysis one this in terms of savings?
Chris
Ive only had ash build up that I brush off when I do the AM stove check and the PM fueling. I used a plastic bottle brush for a couple weeks till I found a steel brush that worked. Wish I could remember where I got the brush as it will be shot by seasons end. Wood boilers have a complete pile of issues as they run a wild ride of temperatures and incomplete combustion and burning wood at 2 to 3 times the moisture. Where there is smoke there is poor combustion.I've wondered what the BTU rating is on a Crosslink type system. Is there a lot of creosote build up on the coils? I've wondered if there was since the coils are a low temp. I remember the build up as being a problem with earlier wood boilers and the stainless tubes and having to chisel off the junk.
agreed!Couple of european companies have H2O hookups. America makes to many lawers to protect idots.
Darwin Theory has been negated by a good medical system, only to be sued by the idots they save.Well I do believe that with 315 million plus people in the US and by definition some 157 million plus being below normal intelligence the lawyers have plenty of potential class action victims.
Me thinks I'll find a way to get a hangnail and sue all of the deep pockets.
Man survived not by being strong but by being smarter. Take the smart away and they won't survive unless by being supported.My two cents as I watch them fish someone out of a frozen lake they tried cross in a car with two kids strapped in the back. Yes booze is involved.Actually Darwin didn't directly address this aspect. Strictly survival.
Man survived not by being strong but by being smarter. Take the smart away and they won't survive unless being supported.
![[Hearth.com] Water heater insert / boiler mod for P61/45/38 [Hearth.com] Water heater insert / boiler mod for P61/45/38](https://www.hearth.com/talk/data/attachments/91/91489-a62179bc033d397eb3b58ef8f5aae5c9.jpg?hash=rwIdHuSMY7)
![[Hearth.com] Water heater insert / boiler mod for P61/45/38 [Hearth.com] Water heater insert / boiler mod for P61/45/38](https://www.hearth.com/talk/data/attachments/91/91490-e2fc1597615c43a2f1e52dcb96183b6a.jpg?hash=2c9QdKZNDg)
![[Hearth.com] Water heater insert / boiler mod for P61/45/38 [Hearth.com] Water heater insert / boiler mod for P61/45/38](https://www.hearth.com/talk/data/attachments/91/91491-5c05c8c0b9c7d80f436b08133d61c6da.jpg?hash=o1HzNF-vjV)
![[Hearth.com] Water heater insert / boiler mod for P61/45/38 [Hearth.com] Water heater insert / boiler mod for P61/45/38](https://www.hearth.com/talk/data/attachments/91/91492-6f038669cea4b4864a947bfaffbbd48a.jpg?hash=7AZgRtIkNr)
![[Hearth.com] Water heater insert / boiler mod for P61/45/38 [Hearth.com] Water heater insert / boiler mod for P61/45/38](https://www.hearth.com/talk/data/attachments/91/91493-a45ee9d5807fff021ffbb2c593eb1a79.jpg?hash=v9kZxGhkvm)
![[Hearth.com] Water heater insert / boiler mod for P61/45/38 [Hearth.com] Water heater insert / boiler mod for P61/45/38](https://www.hearth.com/talk/data/attachments/91/91494-cdccb829fefced6dcb4390bd361d7f24.jpg?hash=X2hNNA60_2)
![[Hearth.com] Water heater insert / boiler mod for P61/45/38 [Hearth.com] Water heater insert / boiler mod for P61/45/38](https://www.hearth.com/talk/data/attachments/91/91495-4af522d29d8dde537764663fbc5647ee.jpg?hash=GlZwHS-8oH)
![[Hearth.com] Water heater insert / boiler mod for P61/45/38 [Hearth.com] Water heater insert / boiler mod for P61/45/38](https://www.hearth.com/talk/data/attachments/91/91496-25119914fb3d404766b6a5d93da4a5dd.jpg?hash=iBK5gO9FcL)
Harmans adjust themselves At 1GPM, the stove will create 18K btu's flat out-full throttle, 36 degree rise. With normal settings (stove mode 5, high fan, feed 4 and a flow of 2GPM) about a 10 degree rise, or 10K btu's/hr. The stove doesn't have an adjustment outside of the feed rate, so I adjust it based on the amount of ash on the burn pot.That's impresive looking. As someone else has voiced a concern, not seeing the fire would make adjustments difficult. What kind of heat transfer are you seeing? The one I made, with running the stove as high as the manufacturer will recommend steadily, I see a 15* rise. That really varies based on the volume of water, yours may flow more volume then mine does but, it will give everyone a rough idea.
Yes it does pigeon hole the insert to a limited brand and models, right now. Other brands can be fitted by changing the plate structure. I haven't worked with other brands,but if this one takes off, then others would be fitted, or if someone wanted one built, I'd build a custom unit / work it out.The only problem I see, is you limit yourself to stoves that don't require you to see the flame to know how it's running. What is your estimated price on these units?
Good writeup- Did you consider copper? Much higher transfer ability than stainless or sched 40. Copper is around 380, stainless at 16, and sched 40/iron is about 80. Might be worth the shot. Maybe if you can find a tankless water heater coil at the scrap yard, it could work.Here's the write up on mine. It was over here in the pellet forum and for some reason they moved it to the boiler side.
https://www.hearth.com/talk/threads/big-e-homemade-boiler-conversion.103685/
You would have holes in the copper in no time from all the products of fire. Think of the copper battery cables and how fast they turn with copper sulfate and thats without heat.I had considered it. Everything I had read about using copper said it would crack over time being exposed to direct flame. I figured stainless would hold up and have no corrosion.
