Skyco said:Hi All! new here- first post.
Picked up the Colonial at the local Northern Tool here on sale for $750.
Waiting on my liner kit to arrive so I can get right to using it.
I noticed the flue collar protrudes through the outer box that air is forced through by the fan.
But-
there is a gap around it so it appears some air would blow out of there, wasting heat and going into the dead ended fireplace opening....
Anyone else see this? Did you do anything about it?
I could weld that gap up, but figure a ring of plate steel with the proper size hole in it would cover that, or maybe seal it with a furnace cement. I fear if I weld it up I could cause some stress as the inner box will expand differently than the much cooler outer box.
I fear some air pressure in the supposedly "sealed" fireplace cavity would tend to force that old smoky smell out somewhere, maybe into the house.
Been out of the wood burning for 25+ years, had an insert in a small house way back that worked great. Had an insert in the current house (been in it 26 years) that worked very poorly, a Matherly. Haven't used it in years, its now out back on a pallet awaiting me to post it on Crag's List for cheap.
I have 10 acres in NC covered in hardwoods that blow down occasionally, figured why let them rot, gonna start hauling the wood from visits. I've got an oak down now that must have 10 pickup loads in it
Well, I noticed that gap on mine as well. Not sure if it will make a difference or not if it does get sealed. This is my first year using a wood stove and I am pretty sure in a few months when im done for this year, I am going to discover a few things I will want to fix. I am glad you reminded me of that crack. I also think that where my liner goes into the stove could use some sealing. One thing I wonder is if it is ok to seal that gap or will it shift too much as it expanded with heat etc. Another concern of mine since I have never used cement is if it is easy to remove. If I use it to seal the gap with my SS liner and then later get a different stove, can I simply hit it with a hammer or something?
Went to Lowes today out of curiosity to see if they had the cement. I know ACE around the corner has stuff for pointing up a fireplace mortar... Same stuff?
Good luck with the stove and please let me know how it goes. FYI, buy some longer screws at home depot to attach the blower. I have my blower about 2 inches off the wood stove for better circ. It's a nice 73 degrees in here tonight with 69 upstairs.
![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
