Rougement said:Corriewf said:Rougement said:"Corriewf said:author="Rougement" date="1260076746"]"Our Testimony as a Company:
"For God so loved the world that He gave His only begotten son, that whoever believes in Him shall not perish but have eternal life"
John 3:16
I kind of like a company that doesnt shy away from the lord. Hope it isn't just marketing though.
Funny, their religious stuff nearly stopped me buying my colonial.
Well to each their own. How do you like the stove thus far? Where do you keep your thermometer? How do you run yours to get it up to 400+ if you dont mind me asking?I keep the thermometer (magnetic condor) on the upper left, alongside the secondary air housing.
I'm not totally in love with the stove but the wood I have is less than optimal. I guess all EPA stove will be picky about wood but I'm still learning. I can get it up to 400 but very rarely over that, it seems to be more luck than science at this point but with dryer wood and more experience I'll get there.
I'm more concious of what I'm doing wrong than right to keep the temps up:
don't block the lower air intake (tough as when the fire burns down splits tend to roll from the back and cover it. I cut all my wood to 18" or so for an east/west fire but now I'm thinking this stove might handle shorter splits placed north/south better.
I've re-split much of my firewood. This stove isn't big enough to accomodate a big split or two and the smaller ones around it for an overnight burn. Because of the smaller splits I'm reloading often. The next stove will have a much bigger firebox.
I'm also wary that I'm alway hitting the air tubes when I reload because of the tiny firebox. I hope they can take the abuse.
I was also wary of the wooden door handle when I first saw it. Now it's starting to brown where the metal enters it. I'll see what Vogelzang have to say about it.
Still, for the money it's ok. I think I'll have recouped the money after one winter's burning by not using propane. Plus, when it comes to shopping for the next stove I now know what I'm looking for - bigger firebox and quieter blower for a start.
I have the same problem with temps. I think there is not a very accurate place to put the thermometer as I believe the temp is much higher than my readings. It take 400+ to get some good secondaries going and I do get them going. I often read between 325-350. I was somehow able to get it up to 400+ on the gauge last night, but I don't know how. I can say I don't notice much of a difference when the primary air is blocked by ash and such. I just try and keep it clean since the firebox is small. I found it better for a good even burn to split most of my wood to about a 1/2 to 1/3 of a normal size split and try to cross them in the firebox. It is funny to hear you worry about the air tubes as that has been a constant bother for me. I am also pretty worried about the boards up there as well. Must say though, they look like they would be easy to replace if need be, and I don't think they will be very expensive. Did you try taking your blower off? I took mine off the unit and pull it about a half inch from the stove. The unit itself just rest on the floor. I get at least double the airflow doing that. Not too sure about the noise of the blower compared to others, but the Mrs wasn't too happy about it at first.
Well the good thing is like you said, for 899 it's a good stove to save some money for a few years and learn the ways of a woodstove. Maybe in a few years with all the money we saved, we can afford something bigger. The good thing about these fireboxes is at least we are not using too much wood.![]()
what's your reasoning behind taking the blower off? Does it suck air in from all around the blower too as well as through the unit itself? Have you experimented with distances to find the best position? I'm not doubting it works but mine is installed in a wall about 3' off the ground so I'll have to do some work to get the blower away from the insert.[/quote]
Well, this is just with the vogelzang the colonial. I probably wouldn't do it with other inserts. The blower and it's housing come as one piece and connect under the ash guard. When I connected it tight to the the body of the insert with the two screws, I noticed very little air being pushed out. When I closely examined the fan and how the housing is designed, I noticed that it was poorly designed. The fan is trying to take air from the same place it is trying to blow the air which was causing a conflict. So I tried loosing the screws and having it set off a little and noticed it pulled air from the gaps on the sides where it was no longer flush with the insert, more air flow. I then took the screws off and just let it sit on the hearth about a half inch from the insert and noticed even more air being pushed through the insert. I would say it definitely needs that gap to pull air from the sides so it can push the max air through the unit. I read another review of the insert on Northern Tool where someone did the exact same thing so it must be a problem in all of these units. It's a problem I can live with. The housing has enough weight to it that being unscrewed I don't have to worrying about it moving much laying on the hearth.
I will take a pic of the housing and upload it in a bit for those that are curious what it looks like and what I might be talking about.
![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
