We have a 1977 VC Vigilant. Right door warped slightly (overheated) and won't seal. I have new doors, but can't get the door off. Left door came off fine with a little WD-40. Right door swings fine, but pins will not come out. Any suggestions?
wd40 is not a penetrating fluid. get some liquid wrench or such, spray the pins well, leave overnight, use a nail set or such and hammer and lightly tap the pins out. can also place a block of wood under the door and tap up that way. don't break the fixed pin receivers on the front panel.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
