Vermont Castings Resolute III Door Issue
arakt1
31
SC
I was almost finished rebuilding my Resolute III when disaster struck...I broke a hinge off the right side door! I was in luck because I found someone on this forum that I got a door from...AWESOME! But, when I went to put the door on I noticed that the frame around the glass was different...the lip was smaller and it only had 2 clips with screws. My dilemma is this...the double glass panes that I had in the old door seems too thick for the new one. Everything else about the door is the same. Any suggestions?
I appreciate the reply. I went ahead and used a single pane of glass on each door. The clips had to be modified, but it worked out fine. Thanks.
just checking the glass you are using is not regular glass right?
