Aha great. Thanks for the picHere is a pic. You can see the horizontal slit in the back with secondary burn and no cat.
![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
The only dealer in Ct I spoke with that was helpful / knoledgeable about this stove is in Newtown, and I don't really want to bother them with this.
sounds right. How much did you pay for cat thermometer?I think anyone running a cat stove should have a cat thermometer, and in fact I'm really surprised all cat stoves don't ship with one. After buying one for my first stove, I actually learned I was burning too cool with the small loads I was running in the early days, with the cat typically below the magic 500F light-off temperature. However, I can very easily see how one could be burning way too hot with full loads, especially when throttling down, as this usually temporarily drives cat temperatures up. If I were processing catalyst warranties, maximum operating temperature would be among the first questions I asked.
Selling units with cat thermometers sounds like the way to go. Sounds like it would save money in the end as i would think less people would be burning up cats during the warranty period....
The maximum operating temperature listed for most catalytic combusters is approximately 1800F, as this is the temperature at which the palladium material starts to delaminate from the ceramic substrate. A few spikes to 1800F shouldn't kill your cat, but frequent operation there will shorten its life.
If you're blowing holes in catalytic combusters, or seeing them mechanically crumble, I wonder if you're accidentally running them much hotter, without even knowing it?
Well, since my stove is stuffed back into a fireplace (and more importantly, I'm a geeky scientist), I decided to go with a thermocouple and thermocouple meter, instead of the typical mechanical dial probe. This permits me to track min/max/ave temperatures, and more importantly, not crawl behind the stove to see the gauge. You can buy a thermocouple probe for $30'ish, and meters for anything between $30 and $10,000. I have a few of the Amprobe dual-channel K-type meters, which I think run $50 - $60 each (Amazon.com), and come with two surface thermocouples. I bought a 12" long 1/16" diameter probe good for +1700F from McMaster-Carr, bent it to 6" long, and it's been working great.
I wish they had offered one of these as an option when I bought my stove!I moved my stove from vehicle to back door with this:
The only trouble was, my wife wouldn't let me bring it in the house. Picky, picky...
If you don't like lifting onto planks (BAR is a brute!), you can use pry bars and fulcrums, going up or down by one 3/4" plank at a time. It's slow going, but that's how I get my machines, and more recently my stove, on and off of dollies. I've used this technique for jacking up and moving items up to 2500 lb. with very little effort or strain on my back.
This unit uses ac power. The ceramic thermocouple cost me more than the controller, but I'm sure I could have done alot better.I'm amazed PID controllers can now be had for less than the cost of a cheap thermocouple meter. Are they also available for 120vac supply now, or do they still require a dc supply?
Nothing can make a mess of your living room like a soot-soaked squirrel on the loose. I had to deal with exactly this situation last spring, before I added the screen to one of my chimneys.
I have woken up in the morning to my decorative panel broken on two different instances in the two years I've had the stove. I do not drop wood in the stove. I have to deal with smoke pouring out the top load while I lightly drop wood in...such a pain!I have been kinda alarmed by the way the refractory panels just sit around the cat, seems very unstable and vulnerable to breakage tome.
Mine says Oct 30 2010.Ah, good idea. Mine says 28 Oct 2010.
I'd also like to add that if anyone would like to temporarily donate either one of these stoves so that we may do the conversion ourselves, you'd end up with a freshly converted 2n1. Preferably someone in the mid-atlantic region.
For anyone that is interested in either donating the stove to us or doing the conversion yourself...
We will be subsidizing a portion of the cost of the parts to you during this period until all the kinks are worked out. The retail cost of the package is expected to run about $700 assuming all goes well with initial conversions.
