If anyone has a Vermont Castings newer stove, I would love to get an educated answer.
I bought a Vermont Castings Dauntless, and so far, it’s been anything but. The one remaining problem I’m having, which no one seems to be able to answer, is that right after reload, no matter the temp, as soon as I close the bypass, it sounds very much like a blow torch.
I am trying to figure out why this happens. Is it gases building in the firebox, is it the catalytic combustor? Which if so, would seem odd that would kick in at a low temp, (low temp only because I tested it to see if it would happen at lower temperature.)
The reason I’m struggling with this is…in the manual, it says if it sounds like a blowtorch, it’s over firing and can cause loss of life. Seriously? Yet, Vermont Castings customer support is nonexistent, and anyone I’ve spoke to in the industry says, ‘I’m sure it’s fine’, without having a clue. I really need an answer so I can burn without worrying I’m doing something wrong. Any help is greatly appreciated. I’m really hopeful someone will have a solid answer.
![🔥 🔥](/talk/proxy.php?image=https%3A%2F%2Fstatic.xx.fbcdn.net%2Fimages%2Femoji.php%2Fv9%2Ftef%2F2%2F16%2F1f525.png&hash=18da44f91a3c9a7f6c18d83254ce3ad0)
