Diabel said:I also spoke with them about the glowing red thing. All three said "too much draft" & it should be prevented 'no stove should glow red'! A manual flue damper is a way to go to eliminate glowing. They strongly encouraged not to tinker with the everburn intake (tin foil fix). I will be off to HD to pick one up & I think at the same time I will get one of these in pipe probe thermometers. The one I have (magnetic) on the flue collar is pretty much useless. How high should I install that damper?
I installed my flue damper about 18 inches above stove. I use it only when the stove is threatening to overfire/ glow red......and after a year I can tell when this might occur....The damper works fine to calm down the fire.
I thought that VC everburn came on the market just in the past few years...
