Vent Pipe Question - Picture Inside
Fatherof2
53
Massachusetts
Hi Gang,
This is a picture of my sump pump piping.
Can I use this same configuration with my stoves piping?
Can I just run the pipe straight up and then out through the wall like I did with the sump pump?
Do I need to run piping up the side of the house on the outside........sort of like a chimney?
[Hearth.com] Vent Pipe Question - Picture Inside
Thanks for any input!
You should check your stove's manual for guidance as well as the vent pipe manufacturer's instructions.......needs to be minimum 18" off the ground but my stove manual says 36".....my local building inspector uses stove and vent manufactures directions to inspect to....if they don't list, NFPA 211 standard..... Be careful if you have a oil tank in your basement......stove needs to be minimum 5 ft away unless a 1 hour fire wall separates the two. (NFPA 31)
Hi Gang,
As mentioned above, your ground clearance needs to be checked. But here is a link to a recent install with pictures of what I think you are trying to do https://www.hearth.com/talk/threads/new-stove-is-in.130569/
