Venting Caulk
QuadUser
20
Way Up North Michigan
I need to add some high heat caulk to my pipe that goes straight out the wall. It's a little leaky as far as cold on one side. I do have some black silicone that is good up to 450 degrees, is this good enough for heat or do I need a higher rated temp caulk ? Ty..
Reactions: Washed-Up
Should be yup
IMHO higher temp silicone is always better, however I can comfortably put my hand on my venting about a foot away from the stove
Reactions: QuadUser
Correct and it will come off when you need to remove it
Reactions: QuadUser
Yep, as mentioned it sticks to itself, you stretch it out and apply it over the pipe joints. I had a small leak on one and it fixed that and I went ahead and did it on the other joints inside. Not bothering with the joints outside. I did however use high temp rtv for the adapter coupling.
Reactions: QuadUser
