Woodsplitter67
yes.. this is when it will happen.. normally back puffing will not happen with the damper open.. when the damper is closed and the cat is on and its back puffing thats an indication of weak draftBack puffing happens when the draft is weak, This is only when I have the CAT engaged and I try to dial down the air flow at night to extend the burn . Its not every night but sometimes when I do try and dial the air back
I'd get a cheap moisture meter off Amazon and check the moisture content.. to narrow down what the problem is.. your going to need to rule out some variables..
