Shouldn't be a problem, should it? Might be a plus even?
I'm about 2/3 of the way thru this morning's log cutting job, stop to refuel the saw and fill the bar and chain resevoir, I'm out of oil. Go out to the garage
and all I have on hand is some 10W - 40 synthetic motor oil. Figure what the heck, want to finish the job and not have to make a run for a quart of oil. So
that's what I used. Seemed to do fine, but only cut for a half hour or 45 minutes.
Also wondering about different saws and how much bar and chain lube they go through. I have a Poulan Pro 16 and a recently purchased Husqvarna 240 series, also 16 inch. Both are 35cc engines I believe. The Poulan will go forever on a fill up of the bar and chain tank. The Husqvarna uses one tank of lube oil for one tank of gas. The tank sizes seem similar on both saws.
Anyone else notice a big differnces in how much oil different saws use?
