Something that ticks me off is when the pellet boiler is running and one or no zones are on, the flow is to the buffer tank. This means that very cool water is returning to the boiler and the protection valve comes into play, big time. Meanwhile, the boiler, which modulates down to 30%, is cranking at 100% to satisfy the the tank.
My goal is to only charge the tank with excess heat.
I am thinking that if I have a mixing valve on the tank return and set it on the high side, say 170, water will only start flowing to the tank when it gets over 170. The pellet boiler water temperature is set manually, say 160, but will continue to run to 181 or so, modulating down until it shuts itself down. I have it set up so that any time the boiler runs, it runs until it shuts itself down.
Anyway, in my plan, the boiler alone will be supplying the loads, modulating down to 30% as it goes past 160, and when the it reaches the tank mix valve temperature of 170 (or whatever), incremental amounts of cold water will be injected into the loop to keep it at 170. Gradually tank temperature will increase until the boiler shuts down, unless the modulating boiler matches the load.
My big idea requires 4 check valves and a mixing valve. I'm not sure it would work or if it'd be worth it.
Comments?![Using Mixing Valve on Tank to Maximize Buffer Use and Pellet Boiler Runtime Using Mixing Valve on Tank to Maximize Buffer Use and Pellet Boiler Runtime](https://www.hearth.com/talk/data/attachments/172/172342-2abc1c3d5665d1a12d3fa7b42e77eaff.jpg)
Comments?
