All I can say is I'll have one with ya.Arrhahaha! Dam idiots sent the wrong wiring harness!...3 wks I waited, where's that bottle of jack.
What was the reason to change the harness? If the connector fits and the harness is good it should work. I would see if the harness they sent you would actually fit the board? If not then will the old harness connect? If so, use that one if it's good.Anybody know if I can use the controll board with the old harness?
Chops the chilly
What will the new board accept? 4 or 5 wire plug? Probably will have to look at the wiring schematic to see what it should be. Is there a difference from the old board and new board on how many wires should be on the plug?New harness has 5 wires onto the molex plug to circuit board the old one had 4. Plus one wire is different color code than other. Thank you us stove
I don't know for sure but I do know a lot of USSC stoves the exhaust fan pulses until the temp gets to a certain point. Mine does and then once it's up to burning good it is steady.Augar is now working. Just exhaust fan start for a second and stop and start and stop.
Yes, that's how it is supposed to work. It loses vacuum so the exhaust fan kicks in full time to stop smoke from getting into the house. Also the light should blink above the Draft Fan buttons when the door is open, showing loss of vacuum. That light should not blink when the door is closed.Well it's weird becouse if I open the front door to were the burn pot is it runs steady. Close it it runs in a pluses
Always better to walk away for a bit...I'm take a break from this thing getting pissed with it
I'd second the jack if I didn't hate it!!Not a problem. I remember 10 years ago, if not for a forum like this my stove would have been on the curb after 2 months!! And jack isn't my favorite, I'm more of a Dopple Bock fan myself, 4 years in Germany and my taste buds just never could go back to what is called beer in N. America.FirepotPete, thanks for sticking with Chops on thisI'd second the jack if I didn't hate it!!
Not if it hasn't reached operating temp. It will only run long enough to clear the auger of pellets. Smoke coming from the exhaust and blower? Is it blocked? Do you have RTV on the exhaust pipe joints?Something wrong. I started it up. Fan was running steady pellets drop ok.pellet start to lite and then fan did the pulse thing. Like little breath could see flame pick up then stall. So I hit on button and fan pick up and ran fine. But got smokey in room could see smoke coming from exhaust at exhaust blower. So I hit off button and it shut down. Shouldn't it run to clear smoke inside burn pot area?
If it turned right off then it wasn't anywhere near operating temp or the auger would have spun for a few minutes. You will have to track down the exhaust leak. Can you post pics of where it's coming from?Yes pipes are sealed and it shouldn't be blocked. I wished I bought another Summer heat made by England it's so easy to run and had little problems with it. Oh when I shut it down it didn't run at all not even to clear pellets as you say. Push the off and it was off.
