These packs were filled with a bunch of little gel cells, like six or so. Don't remember the aH numbers on them.
I don't do electricity. I am a wood kinda guy.
Wood is a much more interesting thing to work with! More rewarding as well.
I've been considering buying a UPS or generator for power during electrical outages.
The CAB50 pulls about 5 amps on startup (just a couple minutes) and then 3 amps on "high". I run my unit on "low"... but there's no data in the manual on how much current the unit will draw at low or medium!
Does anyone have experience sizing a UPS for the CAB50? I've done some initial calculations, and for a decent runtime (12 hours... typical power outage) I'm looking at MAJOR battery cost, plus a few hundred for a TrippLite inverter/charger.
Alternately, there's a nice little 8-amp Generac inverter generator for about 440 bucks.
What would folks recommend?
Well, it's my first experience with a generator. I don't remember if it's a 6500 or 7500. Ours ran for 3 days straight in the blizzard. I don't mind doing most 'manly duties' but I don't like messing with electricity. We had no problems at all. We only ran our fridge, tv, some lights, coffee maker. Obviously, we had plenty of extra wattage available. Hopefully we won't have to run the stove off of it, but I'm sure we will . Hopefully we will get it wired to the house and run well pump off of it too.
I'll jump in on this one with another question. I am sorry if I sound like an idiot-I'm female and new to pellet heating. (And hubby is far from mechanically able!!) We have a great generac generator that has saved us multiple times in the last 2 years. My stove is currently on it's own surge protector. So, when we lose power can I just plug the surge protector and stove right into the generator or is it much more complicated than that?
Well, thanks to all the input here I've made a decision.... I'm going to move slow & get one part of my power system at a time.
My power IS really rotten out here in the boondocks! It goes out a few times a year. Usually only for 4 or 5 hours, but sometimes for a couple of days.
FIRST comes the Kill-A-Watt. I'll determine ACTUAL loads for the pellet stove at all of it's different settings.
SO: THEN comes the generator. It's the least convenient but the best for covering a multi-day outage in the middle of winter! I'm going to get the refurb unit that was linked to above, by Woody1911a1. (many thanks for that link.. it'll save enough money to pay for the inverter/charger!)
After a few paychecks I'll pick up a TrippLite inverter/charger. The basic units aren't "pure sine wave", but I've read a lot of reviews online where people used them for many purposes. Runnning computers was a common use, and I saw no complaints or claims of damage to sensitive electronics. This meshes well with TrippLite's own claims.
A few paychecks later, I'll pick up a 250Ah deep cycle battery. Actual runtime on the battery will depend on what I find with the Kill-A-Watt, but should certainly get me through a cold night, so I don't have to be running around outside starting up a generator at 2 a.m.
If I can get aprox 8 hours of runtime on the battery, then run on the generator for 8 hours, I could actually run the stove, the fridge, AND fully recharge that battery, with the Tripp-Lite's charging fuction.
I have a plan! Now we'll see if LIFE GETS IN THE WAY and ruins my schedule. Moolah $$ tend to disappear for all those reasons we never expect.
Thanks much, folks!
I am in the process of installing an automatic standby 12kw generator and transfer switch for my house. The house has a open loop boiler and when the previous owners lived here they lost power while on vacation and a line froze and burst. When the power came back on a part of the house flooded. They had a small plugin generator and manual transfer switch.
I may still get a UPS because I am not sure if the fuel in the burn grate will burn up during the generator startup and transfer. I also like the fact a UPS will protect from a brown out while a surge protector and generator does not.
Ah!I am no expert but be aware that some motors do not tolerate non "pure sine wave" inverters. My first ups was a modified sine wave and the blowers on my stove sounded labored.....I returned it for a " pure" unit
Ah!
I hadn't considered the motors... only the electronics. I'll have to do a bit more research. Thanks!
Thanks, Woody.also in you're adding "a" marine battery . make that two marine batteries at least for the ups's being mentioned . they are 24V
I've done my research on the wave characteristics of the TrippLite. It a major step BETTER than "modified sine", called "Pulse Width Modulation Sine" . Essentially, many small "steps" in voltage that approximate a sine wave. Many "true sine wave" inverters/ups-es are actually PWM sine wave, with MANY MANY tiny steps, making the resulting sine wave very very close to analog. TrippLite lists many many standard motor types as fully compatible with PWM Sine units, even compressor startups!I am no expert but be aware that some motors do not tolerate non "pure sine wave" inverters. My first ups was a modified sine wave and the blowers on my stove sounded labored.....I returned it for a " pure" unit
