RockyMtnGriz
So you're telling me I need to get rid of two of my sawsThe three generator solution is similar to the two saw solution. Not a bad idea at all. Redundancy for break downs and better fuel consumption by matching the loads are great benefits.
That 650 is tiny though. Must be a real fuel sipper. My version of the fuel sipper is the 2500 suitcase inverter that’s really 2000 continuous output. 30 hours per bbq propane tank.
![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
Yeah, some redundancy in this area is a plus for my situation, though I've never had a breakdown. I wouldn't have the 650 if I hadn't inherited it. Something at least 1000w makes more sense. But the sound level and fuel consumption are great. The biggest redundancy plus with it is I can easily keep it in my just above freezing garage, not my unheated gen shed. I haven't had the problem yet, but if the Yamaha and the 8000w tank ever got too cold to start, I could use the 650 to thaw one out.
Life was a little better watt-wise before the Kuuma, because oddly though the blower on the Clayton drew more running watts, the 650 gen would pull the startup surge. It won't pull startup for the Kuuma, so if it's cold, now I can't use the 650, which was nice to leave silently running overnight. The Kuuma forced me to buy the 3000 Yamaha, which if I didn't already have the other two, is probably all I would have. It's quiet, just not quite as quiet.
Propane would be awesome from a fuel management perspective, but propane starts to get a little twitchy around -40, and a portable tank of propane gets troublesome at temps higher than that, so I'd probably want to be dual fuel, and that doesn't really solve the rotting gasoline problem, but it would reduce the volume I'd have to keep on hand.
I don't know how much the 650 really saves on fuel over the 3000 because a bigger gen has to run every 8 hours or so to keep the fridge happy, and there's usually something else that needs to be powered up occasionally also. Plus, if I've got the 3000 running, I'm lazy and just leave all the breakers on, and go about life as normal, so I use more juice, thus I've never really been able to tell.
Most of our outages happen this time of the year when the ground is soft from snowmelt and the trees fall over. But it's the ones that happen in February that make backup power extra valuable.
