Calentarse
Well this has been a good forum topic. Sounds like your experience with the NC was that of my experience with a VC Encore (although mine did have a crack so it was constantly 650 too with air closed off). Hated burning that thing in a small house! The radiant heat from the cast iron would also run you out of the room!
I now have a BK Ashford and it heats my house perfectly throughout the year! I have had some problems with a smoke smell in the house and the company is working with me on it. They are good at making sure their customers are happy. When you couple that with a quality product you are bound to have a successful business. I could be having issues due to my short chimney, which is not a problem you have. BK recommends a minimum of 15' for chimney height (although my manual says 12') so that wouldn't be a problem for you as long as you don't have any 45s. With 45s, if the cat stalls you may need to create a taller chimney. I have 13' and 2 45s and my BK never stalls; it just emits a smoke smell so important to keep in mind that everyones experience is different.
I would recommend a BK for you because your climate is like mine and need long and slow burns (both because you are busy and because you need the ability to turn the heat down). It's incredible how easy the BK is to operate. The drama is much less with these stoves! It's really quite surprising once you really see how long the wood lasts on a single load.
I would encourage you to get a jacketed stove, like a Pacific Energy (others, right?) or Blaze King Ashford because it keeps the heat down and creates a slower burn. Its a steel stove inside but the outside has a cast iron jacket around it, so it doesn't radiate like my old VC cast iron stove did. It radiates out the front glass, which is nice and not overpowering. If you need to, you can order the stove with the blowers (I think this is typical) and use it as a convective heater).
I don't have experience with the Ideal Steel but my parents just bought a Progress Hybrid and absolutely love it. I've read good things about it and can attest to how good Woodstock is. My parents just switched from a smoke dragon to the new technology and I think Woodstock does an awesome job too manufacturing their stoves., so I would probably buy through them if BK went away.
Best of luck to you!
  It really takes a lot for me to not load the stove full.
