Hi all. I have a trailer that I bought a few years ago which I intended to use only for light scrounging and hauling my DJ equipment around to gigs. It is a home-built single axel, using an old camper (not a pop-up) as the frame. The frame is 10.5' x 6.5', which I'm guessing were the original dimensions. It has leveling stands in the rear, c-range tires rated at 1175 @ 50 PSI max (that are inflated to 35#, per manufacturer label on the tire) and the whole frame is made from 2" x 3" square tube steel - not c-channel or i-channel, full tubes. It has wiring for a brake controller, but I've never used that. The guy I bought it from added 12" and board rails, and I added 4' framed panels (more so people wouldn't see the DJ equipment) all the way around.
Any guesstimates as to how much weight I can safely carry? I've had about 3/4 of a cord of mixed cherry, oak and hickory in it before with no problems. I'm going on a run this weekend to get slabwood, and the guy is going to load me up with whatever I can carry away at once for $45, in front-loader scoopfuls. How many scoops do ya think I can carry?
I can't see anything on the axel indicating a weight rating, but I may not know where to look, either.
