Dairyman
Welcome to the forum djc.
I a confused as to why you wouldn't consider any steel stoves but you are looking at Woodstocks steel stove. The big plus of soapstone to me is that it evens out the heat.
The con's are that the stone could crack, it takes longer to heat up, (not too long IMO) and eventually you'll have to rebuild it.
If you have to go with one stove I wouldn't go any smaller than a 4 cu. firebox.
If we stick with steel I am certainly going to keep my QF 5700 as it has served us very well and is close enough in size/efficiency to the other steel stoves out there. The other option I am considering is to go with a soap.
If I go this route I will be waiting and hoping that the newest Woodstock will be larger than the Progress (and a front loader).
What are the Pro's and Con's of soap? What will happen if it's over-burned (momentarily or continuously)? Are there long term maintenance issues? Are there maintenance perks (I am told that there is no fire brick...that sounds like a perk to me!).
Thanks again for all comments!
But when you add a cat magic happens.
6 cu ft firebox, that should hold you for a while.
