Just to clarify the difference between DIY foam kits and contractor systems:
DIY kits are nitrogen pressurized tanks of the two chemicals that make the foam.
These are susceptible to temperature differences which make the feed rates of the two chemicals vary.
This either yields brittle foam on one extreme to gummy foam on the other extreme.
The results are not always consistent and the whole system is going to yield different mixes as the project goes on.
A contractor will use heated tanks, heated hoses and a pumped system system that accurately meters out the right mix of chemicals.
A contractor can screw up the mix, but I can tell you that the results from someone who does it right is significantly better.
And they can deliver mixes that might stand up a lot better than any DIY foamed project.
I have done a lot of DIY installations in many different situations. None of them compared to contractor installs.
In a previous life, I had worked with a DIY foam company to develop new products. The product is nice for small applications, but they ain't cheap and
a contractor should be able to deliver better foam for the same cost. It also has a shelf life. The isocyanurate can pick up moisture and not flow right if it sits too long.
It is fun to do, but maybe you can get a contractor who is doing the job to let you use his gear for a couple minutes. Then you have
bragging rights and a great job, for the same cost per board foot.
