E
elkimmeg
Guest
Over the past few months I have observed numerous recommendations for masonry heaters, although a great way to heat a home. I feel this poster has missed the mark.
Most are inquiring about a $2000 stove . Telling them to purchase an $18,000 massive concrete /stove alternative is off base. That’s only the cost of the installation not including the support base to hold it up possibly incorporating part of the concrete foundation is needed to support tons of masonry mass the space constraints also have to be considered it could end up costing 25k I wish we all had that kind of money for this option but most don’t it works best at the planning stages of new construction It would be a very costly retro remodeling fit
Another common myth is expounded all too often the 2 cu ft fire box is needed to burn 8 hours for years I got decent heat out of a modern stove that did not have that large a fire box but 1.75 cu ft It burned clean effectively and efficiently Many Osburn 1800’s will burn close to 8 productive hours with a 1.8 cu ft firebox. I agree a larger firebox will burn longer but the airflow is engineered as such to allow even smaller firebox stoves to perform well coming close to that 8 hours burn. Think of the little engine that could.
I think we all have to measure success differently and be realistic wood stoves are space heaters they do not create airflows designed to reach remote bedrooms. I do not subscribe to overheating one uncomfortably out of an area, that residual heat makes it to bedrooms.
To some if the stove can carry the heating load to 10 degrees that could be success enough. To size a stove for once a year or a cold night once in 20 years is overkill.
Even home heating systems are designed to maintain 72 degrees when it is zero out in New England climate zone.
I believe it is best to match the stove that will accomplish realistic goals a stove that can be run efficiently. Over sizing it does not insure efficient operations
I mean I saw a post recommendation for a masonry heater in a 320 sq ft cabin. The heater would cost more that the Cabin
