That is exactly the theory and numbers I use but in reality it hasn't worked out for me in practice. I actually launch at 187 but soon after the center temperature drops about 4 degrees. which means I'm mixing even after all my efforts to keep it from happening.But if you set your launch temperature to 185 degf or so then there will only be one lap through storage. When the 185 degF water comes back around storage will be filled from top to bottom with 185 degF water and you'll be stuck right where you want to be. When my system gets to this point I don't idle, I just shut the combustion fan off and let the fire go out.
