So today I started at the beginning again to do Break in fires 1 & 2 contiguously.
That is the following:
1. First fire. Up to 6 pieces of kindling (1" x 1" maximum). Light the fire (super cedar works great), leave the draft full open and just let it burn out.
2. Second fire. (Stove should cool some but should not have to be cold before second fire.) Same amount of kindling. No more than 2 small or medium splits. Light the fire and let it burn. After splits get burning good, close draft to about 50%. Let the fire go until it is out.
I let it cool down to just a warm stove top after the first one before I fed the stove again and re-lit for the 2nd one.
So the 2nd burn the temps on the top of the stove hit 250, so I engaged the cat and set the airflow for 2. Too bad it was dark in the house because I got a real treat of a light show out of that!
![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
These periodic flame ignitions of smoke gathering near the cat and then probably combusting due to the heat and oxygen still being fed into the stove. I can't explain it, and I expected that flames might cease but I'd see the cat start to glow.. but instead I got these really cool flames that would flare up then die, then flare up then die. Then finally the wood just went to a smoulder.. but, the temp gauge on the top of the stove crept slowing up to 300'F and eventually a bit beyond.
That was this AM about 10:30 EST to Noon. Now, it is 4:30PM and the last embers are still glowing (from 2 small splits I fed in there about 10:30AM!) and the temp on the stove top is down to 180'F. Another observation, when the stove top was creeping slightly past 300'F on the stove top, my 2nd magnetic flue temp guage about a foot up the flue was sitting at a meager 200'F, so what I take away from that is the heat stays with the stove, and not up the chimney!
The wife got home at 3:30 from school.. and wasn't happy that I had the stove still warm and the windows open.
I did explain that there were some fumes, (but it fact the smell of any fumes was pretty damn almost negligible) and I wanted to not stink up the house. So I guess I got away with it.
I think I'll wait until a real cold day to do the final break in fire. As the final fire is really a fire where the stove top temps will reach real operating temps. I do believe that given this stoves history much of the paint fumes and cement curing happened in it's previous life and there was a rebuild as a part of the refurb but I don't think there was a repaint so the fumes were minimal.
One thing I did notice was the difference in heat between this stove and my old steel smoke dragon. I never really experienced this so called "gentle heat" before, but that is exactly what it is, and it is also radiated outward to the various boundaries of the house much more, not just hard radiation in the immediate area around the stove. At least it seems like a more distributed heat.
I'm very pleased and very impressed so far. Did I mention the pretty flames?!
