Ashful
I think the limitations you observed with that machine were unique to that one model, and not a good representation of "hydro vs. manual transmission" tractor comparison. I've seen many hydro machines that have no problem lifting the front end off the ground. Also, I wouldn't consider the possibility that I might have to increase engine RPM X% above idle to pick the front end of the machine up off the ground as any relevant factor in comparing tractors, it just wouldn't factor in to how I use the machine on a daily basis. I frequently find myself increasing engine RPM for the sake of hydraulic speed, but almost never for the sake of hydraulic force, I just hate waiting for a bucket to curl.The bucket position flat on the ground only left about 2 inches travel on the rods. I tried this with the bucket's blade on the ground or the face/opening toward the ground. This position gives more travel, about 8 inches on my loader and permits the removal of the wheel, rather than getting a jack.- don't forget the blocking or the jack stand. BUT, more importantly, if you get the tractor stuck or the front end in a bind or sunk in mud, it permits planking the soil's surface below the tire. And, also permits the operator to use the bucket's edge (in a curling motion) to push the rear of the tractor backwards onto a more solid ground or a surface with more traction- reducing the chances of needing a pull or a wrecker service.
