I do believe its the design of the stove.Do you think it's the bypass that's helping start the wood and nothing to do with the fact it's a cat stove?
I guess it depends on other factors.I do have a top load, down draft stove with after burn and I can tell you from first hand experience you do not get the "light show" once the after burn is kicked in.
Just thought I would throw that out there as the wife was not happy she could not see flames all the time.
A larger cat stove will easily give you a 10-12 hour overnight burn.
Cat stoves do burn with lower flue temps...the flue temp drops as the cat becomes active. The cat burns smoke at 500 degrees, versus a non-cat at 1000 degrees, so a lot of potential heat is not lost up the chimney, but rather burned to heat the home. Because of its ability to burn more of the potential BTUs in wood, and to burn them early in the burn cycle, you get a more steady heat over the length of the fire. You also get more heat from less wood, in significant enough quantity to reduce firewood needs.
A catalytic combustor is designed to be replaced after about five years. It is as easy to replace as a furnace filter...just slips out and a new one slips in. It is not very expensive, and certainly pays for itself in decreased firewood use over its life.
The Woodstock PH has been specifically tested with wet wood and was found to burn just fine with it. The test is available on their site if you are interested in looking at it.
The Woodstock PH has fantastic light show. Again, you can see this on their website, or on various threads here, and on you tube.
It is also a very handsome stove, an addition to a room.
A soapstone stove will radiate heat very evenly for many hours. You might consider a factory rebuilt Woodstock Progress Hybrid as well for your situation. The factory rebuilt Woodstocks are as good as new, and significantly less expensive. It is a hybrid stove, and significantly more miserly in wood usage than even a cat stove. Gives easy 12 hour burns.
I know Alforit found the PH unsatisfactory, but he is the only person I know who had the problems he had. Most of us love the stoves and have been very happy with them, and with Woodstock. I have never taken anywhere near the 1 1/2 hrs. he mentions to get a fire going. On a hot coal bed, my fire is going before the door is closed, and cat reengaged very quickly. On a cold start, which does not happen very often outside of shoulder season, half hour is probably normal for a fully burning fire that does not have to be further attended until reload time.
Just suggesting it is worth considering this stove for your set up, if you have not yet done so.
Sorry to get off topic here. I can't understand how they have enough "rebuilt" stoves available to even market them. This is a pretty new stove to the scene and from what I hear, they make a good product. If they are so awesome, why all the refurbished units for sale? I just find it a little odd.
But why would so many people return them? I don't get it.I called with several questions and I asked about this. They have a 6 month hassle free return policy. They'll even pay return shipping. And when people opt to return their unit Woodstock refurbs them and sell as such.
You have come to a few correct conclusions, but there is also some wrong information, here. Namely, top load stoves do NOT usually spill smoke when you open the top door. In fact, just the opposite: the top door becomes the primary air intake, when opened. I can open the top door on either of mys toves at any point during the burn, and never spill smoke, because it's a well-designed stove with adequate draft. Any reports you've seen of top-loading stoves spilling smoke are likely from those with exceedingly poor draft, likely experiencing other problems with their rig.Hi 7Acres. I am researching wood stoves also and came upon your post. What I've learned so far (whether others agree or not): is that a non-catalytic wood stove is usually easier to start for most newbies. A bucket & shovel is as good or better than most ash pans because alot of those ash pans don't self-cover and ashes spew or you have to remove a plug from under the firebox for the ashes to dump into the pan. A mostly square floor for your firebox is preferable so that when you stock it with logs you can cross them rather than having them all in one direction where they can roll against the glass in the door. You don't want a top loader because when you open it you can get smoke in your face, etc.
Can you run a Blaze King cooler than a PE or Jotul without it dying out? I guess that's how BK gets 30hr burn times, right? They're able to sustain a clean burn with much lower fuel consumption than a non-cat can?
What needs to be stressed with the cat stoves is although you can get long burns ,there is not a tremendous amount of heat coming off the stove when its dialed back all the way.
One member compared it to about as much heat as an electric room heater.That may come up short on a cold day. If your house has i big heat loss you may not be able to run it down so far, thus the burn time will be noticeably shorter.
For me, the ability to dial it back was the reason I suggested the op look into cat stoves. Living in SC the versatility of a cat stove would seem ideal.
Wow, all this talk intrigues me, I have read many threads about long burns and cat vs secondary re burn stoves. And I understand the desire to get long burns, but for me, heat, comfort has always what has driven me. I burn my stoves in whatever cycles, fast, slow, medium, whatever it takes to stay comfortable. When it isn't to cold, I get long burns because I dial my stoves down, but when it is cold, I fire them up and may only get 4 hours. Don't really care.....the temp in the house is what drives me and my stoves. My new little Hampton I put in the kitchen only claims 6 hour burns. I can get 10 or more out of it when it isn't to cold. But when it is cold, I don't worry about more than 4. Well anyway.....just one old timer who has stayed warm for 40 years and enjoyed it all.![]()
And I understand that completely. It really is about "what works for you" Sometimes I do envy you Blaze King guysFor some, it is about convenience. If I had nothing else to do, I would be bored with this Blaze King, but twelve and twenty four hour reloads fit our life at the moment.
This is all 100% true, but should not be taken in the wrong way. Yes, you can dial some cat stoves way back to the point where they're putting off less BTU's than an electric space heater. But, you can also run them full inferno, and get every bit as much heat coming off them as any non-cat. The beauty of the cat stove is the wider range of heat output.What needs to be stressed with the cat stoves is although you can get long burns ,there is not a tremendous amount of heat coming off the stove when its dialed back all the way.
What are the stovetop temps dialed all the way back? Not knocking cat stoves at all .very impressive burn times,but is there a trade off to that long burn?Strongly disagree with #1 "not a tremendous amount of heat"
What are the burn times at a 600 Deg stovetop for a cat stove? Is it similar or much longer than a non-cat?The non-cat guys will have to give the details on what their range of controllable stovetop temps are, but I seem to always hear them quote numbers above 600F in the first third or half of the burn cycle.
I agree. I can only dial my harman back to about 15000-20000 BTUs (guessing) So while its great for cold days its a little harder to control on milder days.The beauty of the cat stove is the wider range of heat output.
That comes down to the efficiency of the stoves being compared. Cat stoves are generally more efficient, so they can produce more BTUs at a lower rate of consumption = longer burn times at same temp. Whether or not that temp is measured on the "top" of the stove is a matter of stove arrangement.What are the burn times at a 600 Deg stovetop for a cat stove? Is it similar or much longer than a non-cat?
