How high do you let the stove top get to before you damper down? Normally I wait till about 650 deg.
ssbn642blue said:How high do you let the stove top get to before you damper down? Normally I wait till about 650 deg.
BeGreen said:How often are you having to clean the chimney?
Right on the money for me. Depending on the wood, I have been known to go to 700. When the wife forgets the stove, Lord only knows how high it has gone.
BrowningBAR said:BeGreen said:How often are you having to clean the chimney?
Me? Once a year. I check on it periodically, though.
BeGreen said:BrowningBAR said:BeGreen said:How often are you having to clean the chimney?
That's what I thought. I am wondering if your stove is being pushed a little harder than Remkel's or BK's? Seems to be working well if it is. Or maybe their wood is less seasoned?
ssbn642blue said:I would like to publicly thank Remkel for sending me the rebuild sheets for the VC Vigilant. To any other owners, ( with his permission ) I can also be a resource for this info. Just PM me and I would be happy to send them to you.
BrowningBAR said:BeGreen said:BrowningBAR said:BeGreen said:How often are you having to clean the chimney?
If anything BK pushes his further. My temps usually run between 500-650 and I will let it ease back down until 300-350 before I reload. I know BK likes to keep his at about 750 and he reloads at a higher temp. But his is a basement install and mine is about 15 feet from me. His pipe temps also seem a lot higher than mine. In horizontal mode my surface pipe temps are usually under 300° even when I am at 600°. I was concerned for a while, but the last cleaning I did showed very little creosote build up (for this stove, at least). Just some chunks sticking to the pipe screen.
BeGreen said:I am wondering if your stove is being pushed a little harder than Remkel's or BK's? Seems to be working well if it is. Or maybe their wood is less seasoned?
