I had problems using my grinding wheel on the rakers. The rakers are wider than the wheel and I had to hit each one several times which left them uneven. Do you grind each one a few times and then even it up with a file or do you slowly move the rakers while you grind? I've been using a flat file on the rakers but I'm slow at it and I have to measure each one. For many guys, sharpening by hand is the best way to go but I would't be able to sharpen my own chains without a grinder.Use the grinder to take down the rakers. It's the most consistent and quick tool you have for this job. You can always round off the leading edges with a file afterward, if that's important to you.
