Just moved into a 1,600 sq ft house near the coast in Downeast Maine. Home has 2 sections, about 1,200 original sq ft (600 downstairs/600 up), and a back add-on a little under 800 so ft (400d/u). The original section (1930) is heated by an oil furnace with forced air and a Lopi 1250 in the front living room.
The back is heated by a 35,000 btu propane wall furnace and floor vents to the upstairs (plus any other air we can direct that way).
The Lopi has a top vent, but is set up to go through the fireplace through an s-curve. Our chimney guy is not concerned since it catches a good draft, as long as we clean it out regularly. I’d really prefer something that rear vents for a better profile and so we can get it a few inches back into the hearth (front legs are on slate pieces at the moment).
We plan on using it most of the time in the winter.
My wife wants a larger stove, but I am afraid we’d just heat ourselves out of our 12x23 9ft ceiling living room, without getting enough heat to the colder parts of the house.
any guidance/suggestions appreciated!
![Thoughts on replacing a Lopi 1250 Thoughts on replacing a Lopi 1250](https://www.hearth.com/talk/data/attachments/280/280484-e7e0c3b95ce20bb8e4857c1801e1f9ed.jpg)
