I had a unique experience this week with my DROLET Escape 1500. The door started to get hard to close and lock. Usually it is a nice easy close-the-door and turn the handle to the lock position. The press and turn got hard like something was stuck between the door frame and the stove. I looked and could not see anything. The next time I loaded it up it was even harder to press and turn. I had a good size fire going so I could not open it up and inspect the inside further. I looked around the outside and saw that the lower door hinge bracket was no longer lined up with the stove bracket. The lower part of the door was much closer to the stove than the upper part of the door. The door bracket was actually binding on the stove itself. Had to be a broken hinge pin. But how the heck could the pin break??? All I could do was let the fire burn it course and let the stove cool down. And hope that the top pin did not break and the door fall off.
Once everything was cool I was able to lift the door off the hinge pins. The bottom one was not broken. SBI uses pins that are not totally round. They have offset round sections. The part that fits in the stove bracket is not on the same plane as the part that fits into the door bracket. Rotating the pin allows for the door to be placed at different distances from the stove. The pin is held in place in the stove bracket by a set screw. Apparently the set screw was loose enough that the opening and closing of the door placed more pressure on the door part of the hinge pin than on the stove part. The pin rotated causing the door to be too close to the stove.
I reassembled the pin and tightened the set screw. I also put some white lithium grease on the door hinge pins. I will be keeping an eye on the pins and applying grease as needed.
Others with DROLET stoves may want to keep an eye on the set screws and tighten as needed.
FYI: The hinge pins are not listed on the parts diagram in the owner's manual. They just show as part of the stove body.
![This was a bit scary...Broken Drolet hinge pin? This was a bit scary...Broken Drolet hinge pin?](https://www.hearth.com/talk/data/attachments/269/269880-637d94b22cf29a0b414ade38b76e40bc.jpg)
![This was a bit scary...Broken Drolet hinge pin? This was a bit scary...Broken Drolet hinge pin?](https://www.hearth.com/talk/data/attachments/269/269874-1c9e983ed3535bc8485444ecfdc72da4.jpg)
![This was a bit scary...Broken Drolet hinge pin? This was a bit scary...Broken Drolet hinge pin?](https://www.hearth.com/talk/data/attachments/269/269875-12ecc1370c95089e14576359936a1b6c.jpg)
![This was a bit scary...Broken Drolet hinge pin? This was a bit scary...Broken Drolet hinge pin?](https://www.hearth.com/talk/data/attachments/269/269876-fa4ea432fed4fb4d1da323892ec5be1d.jpg)
![This was a bit scary...Broken Drolet hinge pin? This was a bit scary...Broken Drolet hinge pin?](https://www.hearth.com/talk/data/attachments/269/269878-2e872942fcd7be8ac155852208a07723.jpg)
