Mike,
I see video 2 is up. I'm LOVING it. Thank you so much for the videos!
I hear you screaming about the smoke hood. I'm working on mine. I have ordered the same fan AHS uses. Dayton states right on their specs it is only rated for 104F. I guess time will tell. I plan to wire it into the purge timer. I figure that way if the purge timer is on to reload, the smoke hood will be also. There also won't be 2 switches to fumble with and the fan will shut off when the purge timer does so no forgetting to turn it off.
How come you aren't using your smoke hood in the videos? It doesn't look like you have it plumbed yet?
ac
PS: I see an unused DHW coil too
ac
