Getting older, have a desire to simplify, minimalize-get rid of extraneous stuff.
Right now, I have a Windhager pellet boiler that I've barely used, along with 6 tons of pellets in the basement, a 200 gal buffer tank with 17 gal ss dhw coil used with the oil boiler, a 20 yr old Burnham cast iron oil boiler with unused boilermate dhw tank, oil storage tank, an unused resistance electric water heater, an add-on heat pump water heater (unused), and a standby propane fired generator with company-owned 1000 above ground tank.
What I've basically been using for heat is my wood insert, with the oil boiler w/buffer tank providing backup and dhw.
I feel the using the 200 gallon storage tank is good because it is very well insulated, and the boiler runs for an hour or so to charge it up. I think that's good for clean running. The combustion chamber and tubes are quite clean when I do the annual maintenance.
I could get rid of all the unused stuff, simplifying things, and making some room in the basement.
Or, I could even get rid of the buffer tank and go with a mod/con boiler with dhw capability and use the propane tank. I think I'd get a better price on the propane, but if I'm still doing most heating with wood, I don't know.
I did the pellet boiler as a post-retirement project, oil went down in price compared with pellets, oil is very convenient, and I just never got into firing the pellet boiler.
What do you think? Rip it all out and put in a mod/con with dhw? Leave well enough alone, and replace components when needed?
Oh, btw, I'm on a fixed income, lol.
