I’m using a wood stove with a catalytic converter, and I understand the risks of thermal shock if the cat is engaged too early. However, my concern is slightly different: during a hot reload, when the cat is already running at 900+ degrees, opening the stove door exposes it to 70-degree indoor air.
In my stove, the catalytic converter is positioned right in front of the firebox, so I imagine it gets a direct blast of cooler air when the door is opened. Wouldn’t this sudden exposure cause thermal shock or stress the cat material?
For those of you with cat stoves, do you take specific steps to avoid this? For example, do you open the bypass sooner to try and direct the flow away from the cat, minimize door opening time, or make airflow adjustments beforehand? I’d love to hear how others handle this situation.
![[Hearth.com] Thermal shock on Cat Stoves [Hearth.com] Thermal shock on Cat Stoves](https://www.hearth.com/talk/data/attachments/333/333686-d1eb39dc2e290a74bd2278c02a9a3e77.jpg?hash=X61uQfN7z1)
![[Hearth.com] Thermal shock on Cat Stoves [Hearth.com] Thermal shock on Cat Stoves](https://www.hearth.com/talk/data/attachments/333/333687-9a09e7d9d9f62aa8edd0fa174599f577.jpg?hash=V8bdFslXSV)
![[Hearth.com] Thermal shock on Cat Stoves [Hearth.com] Thermal shock on Cat Stoves](https://www.hearth.com/talk/data/attachments/333/333689-507a765c0c929da40abfe94bc1537eb7.jpg?hash=vWmhblcIYa)
