It operates exactly the same, same servo, same damper. To be honest, our furnace doesn't get behind often. The only time we dropped below our setpoint at 72 overnight was recently with a nighttime low of -10°F with windchills aproaching 40 below. It was 68°F in the home when I woke and the furnace consumed a full firebox in 7 hours which I thought was very good. Instead of pushing the woodfurnace when I woke, I ran the LP for 1 cycle, about 10 minutes to bring the home at 71° then shut off the LP and the woodfurnace then maintained the home. We are looking at -14°F Thursday night and it may be the same scenario. This morning, it was -6° and 70 when I woke up from overnight. Within 15 minutes of loading the furnace, the temperature raised 1 degree and I closed the damper. From there it climbed and maintained 72 for when my wife got up. If it's that cold and there's a very heavy demand for heat, I won't keep it open the entire time. It wastes wood and pushes heat out the flue. Instead, let it get very hot where it starts to climb and close the damper. It should continue to produce alot of heat, while preserving wood. Once it gets close to the coaling stage and it's that cold, the damper pretty much remains open. The major difference between the two furnaces ( Caddy and Tundra) is the jacket. We have a large plenum opening which allows for excellent airflow thru our ductwork.
