My 362 starts and runs great. Provided I keep fresh fuel in it. don't try to use fuel from last winter. Dump your fuel tank out - into a can and burn it on an outdoor fire. I use 93 octane and the newer silver Stihl mix. I use startech stabilizer in fuel due the dang ethanol. OP never said what type of oil he was running. I mix 1 gal at a time to keep it fresh. Push decompression button down. Should always get it to "pop" with control/choke lever all the way down, on no more than 7 pulls. Push lever up one notch and should fire within 1-3 pulls.
If I ever have a flooded condition, which I have on my 250, you take off the muffler (2 bolts and a gasket) and it will fire right up on choke (and run loudly). Put it back on and problem solved. I learned this from my chainsaw dealer and have done it a few times with success. Your shop charged you $50 to do the same.
By the way that is some gnarly oak Roundgunner, you need the 362 for that!!
