Hi folks.
A couple of weeks ago our new Morso Owl 7kW stove was installed. It's not so cold here yet but despite that I've been firing it up on a few 'test burns' to see how it goes. So far, so good - the heat output is quite low but that appears to be due to the lower chimney draft due to outdoor temps in or around 60F right now.
Due to having to get up reasonably early (0545hrs) I typically hit the sack at around 1030hrs. What I'd *like* to do is to load up the stove just before bed, with a load sufficient to provide a gentle heat until morning, at which point I would hope I could place a log or two in and get it started again. What I have found, though, is that the Owl eats its way through logs fairly quickly, even when closed down a fair bit. Is this a characteristic of having to compensate for a relatively poor draft (in current conditions)? Am I likely to be able to get my overnight burn or is this unlikely?
The firebox of the Owl isn't particularly large - I reckon I could fit a maximum of around six 12" logs in there at any given point in time. Is this enough for an overnight burn?
Also, any tips for overnight burning? Chimney is 12m, stainless steel lined inside of a fairly decent clay liner, stack is internal and draft ought to be quite good all things considered. Logs are typically split hardwoods, though of varying types.
Thanks,
John
Thanks,
John
