Thanks for the input ,1750, I appreciate itYes, the weight is impressive! Don't put the bricks back in until you get it where you want it!
I'm really new to wood stoves, and all I learned, I learned from the helpful folks on this site.
This stove seems to work best if you build a small, hot fire and really get it going with the air control wide-open. After it's going well, add more wood with it still open and then damp it down slowly to control your wood consumption. I've had no trouble getting it to last the night if I fill it up before we go to bed; I can shut the air control all the way down and keep it burning through the night.
I have had lots of trouble with the thermostat in the blower. The original problem was that it was in the wrong location (BG helped me sort that out). And then, once I got it into the right position, it worked well for awhile and then got really inconsistent (i.e., it would come on at 400F, stay on for a few minutes and shut down again, off and on even at 500 and 600F). I finally just took the thermostat out and jumped across the circuit to hard-wire it to the blower. I had the dealer order me a new thermostat over the summer, and will install it again soon to give it another try. If it doesn't work well, I will probably just permanently wire the fan to the blower (with no thermostat), as I like being able to turn it on whenever I want to -- the only downside is if the fire dies and we aren't paying attention, the blower just keeps on blowing.
Oh, and I also had trouble knowing what to do with the blower control. We have a corner install, and the cord was too short to attach it to the wall in back of the stove. I ended up getting some powerful little magnets and attached it to the heat shielding in the back. It doesn't get very hot, and it's nice and convenient.
Good luck with your new stove! Understanding that I don't know very much, if you have any questions specific to the 1750, I'm always happy to try and answer them. I'm guessing, however, you will probably know more about it than I do before the week is out.![]()
![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
. I thought that the intake air came in through the holes in the front , but apparently not , it appears that air comes out there from the blower.
Have you ever looked at the air control on the bottom ? here is A couple of shots , kind of strange the way it is shaped .
![The New To Me Lopi Republic 1750, Is Home The New To Me Lopi Republic 1750, Is Home](https://www.hearth.com/talk/data/attachments/109/109365-098934452d8bb4e2e5053ab11c65069a.jpg)
![The New To Me Lopi Republic 1750, Is Home The New To Me Lopi Republic 1750, Is Home](https://www.hearth.com/talk/data/attachments/109/109366-66bbd0bbf75c9429cc1e49f28a419ea1.jpg)
Thanks Pete , I got her up on her pedestal now , I used some blocking and the farm Jack ,to raise it up on the 12" high hearth.Way to go HD looks like a nice stove ! You should be real warm this year.
Pete
Once I got All the brick out and the heavy steel baffle supports, it was much easier to deal with ,I put some furniture sliders under the legs , slid it out of the trailer across the back deck , and into the house .I haven't put on the new door gasket yet you see old one hanging out in the picture
![Eek! :eek: :eek:](/talk/styles/default/xenforo/smileys/bigsurprise.gif)
![The New To Me Lopi Republic 1750, Is Home The New To Me Lopi Republic 1750, Is Home](https://www.hearth.com/talk/data/attachments/109/109367-7d3a966a46726abe8292c783aef769cc.jpg)
Thanks for the input ,BuckthornBonnie, It sounds like U R very happy with yoursWell said, 1750. I'll add that there's a bit of a learning curve with any EPA stove, but the 1750 makes the transition a bit easier. The single-lever control on my Spokane is almost idiot-proof. I find that there's a "sweet spot" you'll just have to discover by messing with different loads. I got it a bit hot a few times this winter, but nothing a box fan and time couldn't control. I rake the hot coals forward and like to do cigar burns on overnight loads. I also pack it pretty darn full but am mindful of it all going off at once. My parents have an old 1980s-era Blaze King (smokedragon) that I was used to operating before the 1750... there's a big difference haha.
A hot and small fire at startup is usually the key to a great burn. Obviously don't throw a ton of super-dry wood on a hot coal bed, that's a quick way to get things going a little too hot. I'm OCD about my glass, so I keep a paper towel or two handy to wipe down any residue or haze as soon as it appears. I think we had dirty glass no more than 3 times all winter (not the best wood, at times). Like I said before, dry wood will set off an amazing secondary show. I specifically remember a couple loads of cherry that were pretty darn sweet.
In terms of clean-up, I remove my double wall connector and clean it on my deck (right near the stove). Then I run my brushes up from the clean-out T. I have quite a bit of chimney and the cap extends pretty far up from my roofline. So far, so good on the cap staying clean. At most I've gotten about 2 cups of dusty material out of the pipes. It'll be even better this year since I'll be burning better wood. I vacuum out the stove, check the tubes and baffle bricks, then fire her back up. The total job is about an hour or so and I did it every month during a warm-up.
If I think of anything else I'll PM ya... good luck and have fun with it!
![Cool :cool: :cool:](/talk/styles/default/xenforo/smileys/shade_smile.gif)
Ya I think I did goodWelcome to the good side of The Force. Be patient with the learning curve. Things gonna be different but you have been around here long enough to see lots of the threads with folks getting settled in with new burners
hell of a deal ya got there.
Finding a good used stove to fit what you need is not easy , it would have been so simple to walk into a store and buy one .
I did learn a lot about different stoves while looking .
I started looking for stove last fall and winter , but with not so great of wood I decided to run the smoke Dragon until this year when I will have good wood.
I should be burning less wood now .
What I have read Here is some people with new EPA stoves have problems with not so great wood , and choking it down too soon after they fire it up but , you can have problems with a smoke Dragon also if you choke it down too soon .
My old stove had about five different ways of controlling the air , this one should be a piece of cake
![cheese ==c ==c](/talk/styles/default/xenforo/smileys/cheese.gif)
I don't think I would ever even conceder buying a cast iron stove.BTW: Have I ever mentioned that steel stoves rule!
My old steel stove is over 30 years old ,nothing ever broke , the only maintenance I did was to clean .
The guy I bought the house from heated with it for five years before he put a furnace in, then used it part-time, I used it part time, then started using it full time when my furnace broke, spring of 2012 , from now on it will be wood heat 100%
Edit I forgot, I did buy a piece of crap boxwood stove one time ,put it in pole barn, I didn't know any better then
![lol ;lol ;lol](/talk/styles/default/xenforo/smileys/lol.gif)
