The magic of 999999
peakbagger
8,979
Northern NH
That is what my household meter read today. Prior to upgrading to my pole mount PV last June, I usually still had to buy power from the utility in January and February as I had used up my credit from the prior summer. Therefore my meter slowly crept up for a couple of years. Since last June with new capacity installed, the meter has been slowly running backwards even though I added a small freezer and used electric resistance heat occasionally. As of today my meter flipped over from 1 kW to 999999 KW. Really its just an arbitrary point but sort of like watching a car rollover its odometer, its nice to note. Bummer I missed the actual point where the number flipped.
My electric bills are amusing, the utilities billing system really doesn't deal well with net metering, they attach a graph of past usage and the degree days to compare to the prior year to the current usage, on months I generate more power then I use, the program defaults at 320 KWhr/hr average. For quite awhile I got a real letter sent by a person telling me how much credit I banked but for the last two months the computer is trying hard but still not real happy.
I am adding another 2 KW of PV in the next month or two. It will be used with a split heat pump and offset my wood usage plus provide some backup if I am not around to feed the stove. Looks like I need to keep an eye out for some electric baseboard.
With net metering and mini split heat pumps combined with cheap solar and the fed 30% rebate for solar, its starting to look like heating with PV is competitive with other sources of heating. I expect with SRECs and FITs its even more attractive.
As they say in German...Kool!
I predict they will charge you 999999*$0.15 = $149,999.85.
How did the 30% work out for you?
I did my taxes a few weeks ago and the IRS shorted me almost $4000! They only allowed about $400 refund for this year and put the remaining $4k as a "credit" toward next year! ::-)<>
It's been nice and sunny here for the last few weeks and I've been making around 15kw/hr a day on my panels. I generally use only about 400 kw/hr a month.
This is my setup: https://enlighten.enphaseenergy.com/public/systems/kqxA100729
The 30% credit works fine for me, I pay enough taxes to take the full credit. Folks with lower income apparently are better off with a lease as the leasing company gets the credit and in theory uses it to buy down the install cost.
Dunno. I made about 75k according to the IRS last year. Some write offs with the house and business, but I don't have any dependents other than the dog, 6 ducks and 17 chickens.
They only allowed about $400 refund for this year​
Maybe they figured a % according to the time the PV's were up and running last year.
I was thinking about getting some chickens. Not as pets though. What's been your experience.
Still think you should reaim the PVs.
That just shows what you know about electric utilities. They're only going to charge him (999,999 kW - 1 kW) * $0.15/kw = $149,999.70.
Let's not get carried away, here.
I suspect they will actually charge him $0.1500010 per kWh so it will still work out.
Reactions: Ashful
