iceman said:ml said:Edthedawg said:Iceman - you got it wrong, bud... Adding insulation stopped the stove's heat that was going up around the liner. That allowed portions of the stove which never before got hot to finally warm up to the curing temps. The fire itself has been plenty hot all along - i'm sure this did nothing at all for her DRAFT.
Adding insulation now would likely help her with future cleaning as that uninsulated liner in her big exterior chimney is pr
obably gonna condense a lot of creo. luckily it sounds like her wood is pretty good.
Seems some of us still wonder "what`s up"
first... A 5 gallon bucket of insulation quote from earlier thread... Is not much... but a roll of store-bought about the size of 5 gallons is a much larger pile.Enough where I would dread having to reach past my sourround having been removed, and get it all up that relative small opening. How much could really be up there? Use a stick to push it on up?...How long could that stick have been???
those pipes cool seriously fast people...creo is real... finish the job.
I keep seeing a pot of boiling water sending a columne of steam up.. that represents no insulation.. now put a lid on it and that represents your insulation no more steam rising... but the pot temp never changed...I still wonder!
What I don`t wonder about is that...Hampton spent thousands, and more of em, to develope this technology of secondary-burn, wash systems,(i wish i could see past my doors) ect.,ect. to conform to EPA and be competitive with thease cleaner burning fuels and stay in the market... why can`t they answer the simple questions they found answers to long ago?
i just found it hard to believe but i guess it makes sense?? because of a soft block-off plate the stove got warmer??? that is draft it was not enough because too much cold air was cooling the pipes not allowing the stove to really heat up... right? thats the reason?? with a raging fire the stove still shoulda got hot enough to cure it... the heat just goes up the chimney??
so... do to her lack of insulation, it allowed to much cold air down the sides of the pipe in which the pipe wasn't able to get hot enough to "draw up" with any intensity.... i guess ... just trying figure it out
Someone said earilier, the proof was in the pudding....I don't know as much as everyone else about draft and what not, all I can tell you is that with the same wood, and the same burning practices, my house is about 5 degrees (2 floor 1700sq feet) warmer since we put that insulation in. It seems like we were heating the whole masonry chimney, and the insulation helped the heat stay in the firebox. Am I simplifying it too much? Please don't detect sarcasm, I don't actually know, just learning. All I can tell you is my problem is a whole lot better now and that I will be insulating the rest of the chimney as soon as I can figure out what to put in there, so as not to creat a creosote problem. Seems hard to believe that something so simple could have made such a huge difference, but it did! I wasn't even confident it was going to work, but my thermometer in this room says it is 82.2 degrees
