My Hubby's 26+ year career is based on this...sometimes you just can't fix stupid
As a volunteer firefighter, if you were in my "catch area", I would encourage you to call the fire department and have them heading your way just in case it gets away from you...it's much easier to put out the fire if it happens to get in the walls when it's small and just confined to the area around the stove (and besides we like to drive our big red trucks with lights and sirens going and are always looking for an excuse ;-) )
If you've got it out when we arrive, we can take a look with our thermal imager and make sure that everything is good with your floor/walls/ceiling...pack up and go home.
If the issue is just in the stove, or the flue pipe connecting to the chimney we'll usually take a dry chem fire extinguisher hose, just crack the door and give it a quick squirt...if you do it right it's all drawn into the stove, up the chimney and doesn't make a mess in the house, sometimes it take a few squirts..that will usually knock the flames down enough so that we can let it cool off some then we can start pulling wood and coals out of the stove and take them outside...
If you've got a chimney fire going (go outside and look at the top of your chimney, if it's really cooking you'll have flames and thick black smoke pouring out of the chimney), then we go up on the roof and start dropping dry chem "bombs" down the chimney and that usually will snuff the flames down enough so that we drop our chains down to break up the creosote that is burning inside the chimney, then a few more dry chem bombs, then remove the burned stuff out the cleanout...
We usually always "red flag" a chimney until it gets inspected and given a clean bill of health. Depending on how long it has been burning it can ruin the chimney and can be very expensive to fix....which is why everyone should clean their chimney at least once a year...
We have a couple people in our catch area that pride themselves on having a chimney fire at least once a year and having us come out to clean their chimney for them...which really p@#ses me off since one of these times their chimney fire is going to turn into a structure fire and they're going to lose their house...and put me and my fellow firefighters at risk...sometimes you just can't fix stupid...
That's my experience and it makes sense. 3 cu ft of kindling will burn very hot & fast vs. 6 pcs that equal the same 3 cu ft. That's an extreme example but you get the idea. The problem for the last 2 winters for many of us has been that we're using wood that is not as dry as it should be because it's been so cold, our wood supply of dry wood gets depleted early. I've solved that problem now.So burning larger wood should burn and out gas slower and burn longer and cooler
like i said you may get away with it many times but it is still very unsafe. The dangers just are not worth it. The last resort to me is a fire extinuisher water should never be an option at allYou are right, it is a possible problem. Not to make my water method sound correct but there was no 'major' steam that I saw and zero came out the stove door.
i have used ash before to slow a fire down. But wondered about it having an effect on secondary burn. Since the burn is happening above the wood.I have seen sand and dirt mentioned a few times in this thread. If using that is your inclination (not condoning or opposing in any way) - why not use a bucket of ash? Its also non-combustible and as a wood burner - readily available.
ETA - one other option that I did not see mentioned (and I have one in reserve) is a chimfex.
http://www.amazon.com/s/?ie=UTF8&ke...qmt=e&hvbmt=be&hvdev=c&ref=pd_sl_86tfrv2ps2_e
It seems to me that this was not an issue with the old air tight stove. Shut the air off the fire dies. So why don't the add an "emergency brake" to secondary burn stoves. You know PULL THIS IN AN EMERGENCY handle. To shut the air off fully.
SO the way i see it. The over-fire happens because of excess out gassing once the secondary start burning. Then the out gassing increases as the temp rises and bingo run away. So burning larger wood should burn and out gas slower and burn longer and cooler. Or am i looking at it wrong?
A 4" sewer drain valve to a motor home. Hard mount it where the air line comes in through the wall, then run your flexy hose to the stove. You could do a full air shut down if you chose to. If you were using it as a damper the stove would smoke and polite, so don't do that.I have looked high and low for a small damper to put in the OAK line
Never thought about that. Basically a gate valve. ThanksA 4" sewer drain valve to a motor home. Hard mount it where the air line comes in through the wall, then run your flexy hose to the stove. You could do a full air shut down if you chose to. If you were using it as a damper the stove would smoke and polite, so don't do that.
They are cheap and airtight. The plastic could burn, but so can the wall it would be mounted against.Never thought about that. Basically a gate valve. Thanks
This is asuming that the port in the stove for the oak is actually sealed and it cant draw air from elsewhere Many are not sealed at all so blocking the oak in those cases would not change much. But on some stoves it would work very wellA 4" sewer drain valve to a motor home. Hard mount it where the air line comes in through the wall, then run your flexy hose to the stove. You could do a full air shut down if you chose to. If you were using it as a damper the stove would smoke and polite, so don't do that.
you cant on most and it is very rarely an issueYeah, i don't think i would ever buy a stove that had a seconary intake i couldn't get to.
That's not a stupid question. I posted earlier that I suspect many people have overfires and don't even know it. firfighterjake said it best, most folks are not aware of how hot their fire is without a stove pipe thermometer. So, in your case, you can buy and install one if you want. There are a few options but my choice is here: http://www.auberins.com/index.php?main_page=product_info&cPath=17&products_id=292Stupid question I suppose, but not to ask would be worse.
With an insert and no view of the stove pipe, how would I know if I've over-fired? I have a IR thermometer and top center of the insert on the exterior just above the fan outlet might reach 500deg during a very stout burn.
Thanks.
