Other than a bit of a waste of fuel it's not harmful for a short spell, though I would take it down quite a bit, especially if the chimney liner is staying clean. The last sweep I took out well under a cup of dusty soot and that is running with a cooler peak flue temp. As long as the wood is well seasoned, try taking the flue temp up to 6-700F max and see how the chimney looks. If it stays clean then there is no reason to go hotter.Hello begreen, I have always run up to about 950 degrees my first morning fire flu temp with a probe, to try to clean out anything from the p.m. burn. Hearthstone Equinox. I'm not worried about chimney fire I have a stainless steel liner insulated inside a 12-inch tile masonry chimney. Do you think that that's too hot and I am causing problems with my liner? my chimney is cleaned by me once per year and it's looking great but I sure don't want to be harming my liner. I've had this stove setup for about 5 years. thank you for all your experience
