Hi everyone,
I'm looking for suggestions on the Supreme Opus double sided stove. It is a beautiful unit, but no matter what I've tried it smokes every time the door is opened to reload. It just doesn't seem to draft very efficiently.
Originally I had it installed in the very center of a small (1300sf) not airtight 2-story house. It was vented through a straight 6" double wall stovepipe connecting to the 6" insulated Selkirk chimney. The double wall pipe is about 12ft long (because the stove was installed in the full 2 story opening of the stairwell) followed by 11ft of insulated chimney that protrudes 5ft above the peak of the roof.
I've tried opening the door at different points of the burn cycle, opening very slowly, even tried reloading with the patio doors wide open and smoke still escapes into the room. I eventually had to replace it with my Jotul model F3, and older model 8 at my wife's insistence. I have no problem with either of those woodstoves. I can even burn them with the door wide open and no smoke escapes.
After replacing it I moved it into my workshop which is also 2 story, but only has 5ft of double wall pipe into 15ft of insulated chimney again straight up (no bends). Still the smoke escapes![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
Any other suggestions much appreciated.
Thanks, Simon
![Supreme Opus Smoke Problem Supreme Opus Smoke Problem](https://www.hearth.com/talk/data/attachments/125/125880-46b05b9d0f89918e39598425646ba16b.jpg)
Thanks, Simon
